Help with plumbing for garbage disposal
Discussion in 'General Plumbing Help' started by ptremblay, Jun 20, 2019.
  1. Jun 20, 2019 #1
    ptremblay
    ptremblay
    ptremblay
    Jun 20, 2019
    Montreal, QC
    So I've been tearing my hair out over this for the past 2 days, buying all kinds of adapters that don't seem to find, and now I'm ready to throw in the towel and ask for help :)
    Pipes from the wall: 1 1/2"
    Sink drain: 1 1/4"
    Here is what I tried so far, and I sincerely apologize for butchering all of the terms, hopefully you guys can make sense of what I'm saying
    1 1/4" -> 1 1/2" elbow connector to connect to the GB drain
    The 1 1/2" connects to a straight 1 1/2" pipe
    Straight pipe connects to 1 1/2" tee hub
    Then I have an elbow connector with one spigot end and one hub/socket end
    Problem #1: I can't connect the hub/socket end to the house pipe using the nut, but I can't find a spigot/spigot elbow connector anywhere
    Problem #2: I can't find a 1 1/4 straight pipe to connect the tee to the sink drain - should I be hooking it up to a 1 1/2" pipe and then use a reducer or a washer?
    Any help is greatly appreciated
    [​IMG]
  2. Jun 21, 2019 #2
    gagecalman
    gagecalman
    gagecalman
    Nov 11, 2016
    68
    11
    Baltimore, MD
    I think your drain might be too high.
    The fitting in the GD is in backwards but you'll probably have to use a straight tailpiece instead.
    Here is what you're shooting for:
    SHEPLMBR likes this.
  3. Jun 21, 2019 #3
    ptremblay
    ptremblay
    ptremblay
    Jun 20, 2019
    Montreal, QC
    Thank you! I didn't realize that the fitting in the GD was backwards! :) OK now I have a better idea of how it's all going to connect
  4. Jun 21, 2019 #4
    gagecalman
    gagecalman
    gagecalman
    Nov 11, 2016
    68
    11
    Baltimore, MD
    You are welcome. Post a pic when you're done.
  5. Jun 21, 2019 #5
    PlumbGate
    PlumbGate
    PlumbGate
    Jul 13, 2018
    176
    27
    Maryland
    Don't forget to punch out the hole if you are going to connect a dishwasher to it.
Draft saved Draft deleted
Share This Page
Group Builder
