Hi all,
I need some help to fix a leaking bathtub faucet. I've removed the side screw from the tap handle (I believe it's an old delta H22 model) but the handle won't come off.
I tried to pull it out gently and then with a little bit more force but it still won't come off. Should I put in even more force or is there something else that I need to remove first?
Below is an image of the tap handle.
Thank you so much.
Thank you so much.
