I've been chasing this leak for at least a year now. Hopefully someone can help.
My powder room toilet leaks from under the toilet at the floor. What I know:
1. The supply line is NOT leaking.
2. The Tank is NOT leaking.
3. There is no CONDENSATION on the outside of the tank or bowl.
4. Liquid is from the bowl, not the tank as the floor smells of urine.
I have tried 3 or 4 different wax rings. thin ones, fat ones, ones with the 'funnel' attached.
Picture of current 'ring' attached.
I have silicone sealed the top of this flange to the bottom of the toilet. After it still leaked, I have removed the toilet to confirm that the silicone is holding and that there are no weak points between the top of the ring/flange and the bottom of the toilet.
I HAVE REPLACED THE ENTIRE TOILET because I thought sure there must be a crack in the old one.
I have installed an additional studor vent under the sink the powder room thinking that it was a vent issue.
There is no obvious flow restriction in the waste pipe as toilet flushes well and always eliminates all waste with a single flush.
Since the ring/flange ring thing is tightly sealed to the bottom of the toilet it seems that the leak could only be coming between the pvc pipe and this 'ring'. Is there a minimum vertical drop that is required before the waste line is elbowed? My elbow in the floor is attached directly to the toilet floor flange. Perhaps the discharge water is splashing back up from the elbow because there is not enough vertical distance ????? Seems like a long shot, but that is all I can think of.
I have looked at the pipes from underneath in the basement, there is no EXTERNAL leak. Floor flange is screwed to the subfloor, so it is sturdy, and it's glued to the elbow.
The more the toilet is flushed the more the leak. If there is no flushing, I don't think it leaks.
Anyone want to take a crack a this one???
