To make a long story short, I got a screw stuck in the old garbage disposal and since it was really jammed in there I replaced the garbage disposal with a new one and all was working fine.
Then shortly afterward around the same time, can't remember which happened first, I stupidly put a little bit of corn husk down the garbage disposal. It didn't like it but it went down, I didn't put anymore down there. Also around that time we noticed a small leak and I tightened the pipes below.
Now whenever I use either sink, after a certain amount of water, the other one backs up. Then they will slowly both drain down. I'm inclined to think it's not due to the corn husk because I don't think that would explain why the non garbage disposal sink gets backed up. I snaked all the pipes and didn't find anything. I don't really know what the problem is.
Attached are the pics of the plumbing. I'm not exactly sure how the plumbing looked with the previous disposal but I think it is currently pretty close. I'm thinking maybe the pipe exiting the non disposal sink isn't slanted down enough. Any help or suggestions would be appreciated.
