Quantcast
e one Grinder Pump - Help Please?
OldReturner
Aug 7, 2020
CT
Evening
We had a 3-day power outage and it worked fine before the outage.
The usual happened - the basin got full, the alarm went off, and I hit the silence button. It was running but water was NOT being pumped out.
I tried turning off the breaker, letting it run, turning off the breaker, but to no avail.
I then lifted the unit a bit and rested it but still in the water. I turned it on and water WAS pumping out of the discharge hose.
I opened the ball cock and water from the sewer did shoot up into the air.
I then removed the entire unit and hosed it down and checked for any visible clogs which I found none.
I replaced the unit and turned it on, it runs, but no water is being pumped out.
Other than calling in the professionals and spending a wad of cash, any suggestions? Thanks in advance!
breplum
Professional
Professional
Nov 14, 2017
649
234
Lafayette, CA
most pump setups have a vacuum relief hole either in the body of the pump or drilled in the pipe just up from the pump volute.
Possibly there is a clog in the hole.
OldReturner
Aug 7, 2020
CT
I appreciate your advice! I pulled the unit out again a bit, turned it on, and sewage water was freely flowing out of the exit spout at what I believe to be a normal rate. I pulled it out all of the way, laid it on the grass and hosed it off really good and did a careful inspection. I didnt find any holes (nor on the schematics of the unit online) nor did I find any clogs.
I put the unit back in, turned the power on, and it is running and running but to no avail. Logically I dont get it as it clearly pumps water. Could a city-wide power outage for days backup the sewer system to where my pump isnt able to overcome the city sewer's backup?
SHEPLMBR
not a Junior Member anymore!
Sponsor
Mar 9, 2016
959
203
Augusta WV
An E-One system is an engineered product, if I am not mistaking, for a forced main sewer. You need to call someone well versed in these systems.
