lukeiam
Thanks for clicking! This is my first post...So I appreciate you even looking...So I will get right to it!
I've done a lot of the renovations on my duplex (I live in it), but plumbing -- because it needed extensive roughing in and new sewage lines -- was mostly left to the pros. I did drains and such for my sinks, but never messed around with copper much. So wanted to ask the good folks here because there's A LOT of knowledge here.
All my copper lines are new to both bathrooms. Flash forward to yesterday and I hear a siss sound coming from my closet. I cut open the wall and it's a pinhole spray at the elbow for my toilet line.
I could call my plumber, but I wouldn't mind learning a bit more about this process. Before, when I was looking around at PEX and compression valves I thought it was inferior. But, now I'm looking at a faulty elbow that's like 5 months old! This damage could have been severe if I'd been gone.
I'm showing a few pics of the layout and what I'm proposing. Note: pic 2 obviously has a 2x4, which I'll sawzall out. What I'm wondering is if I can cut the copper in the basement (pic 1), run a compression coupler (eg, sharkbite) to pex, then a compression elbow to something for a stub out to the shutoff in the wall? This seems pretty straightforward for converting copper->PEX.
The water to this area has been drained and shut off upstream.
Thanks for much for reading!
