Cracked Valves
Here is a pic of the finished installation just as it was before the cracked valves. I am thinking that whole assembly needs some type of support . Not sure what kind or the placement of such support.Sprinkler Assembly.jpg
I took the easiest way out. Removed old manifold from cracked valves and just added two couplings. Ready in two hours. When I had a sprinkler guy out to estimate the cost, he said what is done here is against the code. He indicated that the shutoffs valve should be in the front. Which did not make sense to me. Anyway, I think I will get some type of strapping material to fasten the whole thing.
You could easily dig that up and correct the piping then lower it and plant something around it to hide it or get a fake rock.
Ask the sprinkler guy if he follows code on every job no matter what ? 🤣 If he says “ yes “ then find a sprinkler guy that doesn’t lie. 🤣
