Thank you Valve man. I will try that or something similar.Lot of clicking going on with those type pumps. Can you put the pump on the other side of a wall and run the supply and feed lines through?
Twowaxhack, thanks for the advice. I am going to encase this pump and hopefully never hear from it again.The noise is probably being transmitted through the pipes as well.
Use some pex to connect the pump.
Concrete block filled with sand helps control noise too. Build a wall with it.
