blackbull1
I just moved into a new home and found our one bathroom has a Cadet 3 toilet. The issue I have, is the bowl level seems kind of low to me. The toilet seems to work fine. I don't know if its the limitation of the toilet, ( 1.28GPF) or if its truly low. I do notice if I turn the fill valves bowl level all the way up, the bowl will fill to what I would consider an adequate level, (pic 2) but within 30 seconds the water level, (pic 1) seems to drop an inch or so. The pictures show the levels. It was manufactured in 2010. Pic 1 is after the toilet is flushed and 30 seconds later that's the low level. Pic 2 is right after you flush and the tank stops filling. Could this be a trap issue? Or is just normal?
