Hello I am having repeated problems with build up in my cast iron pipe at the first bend in the pipes below the toilet.
I had a plumber out two weeks ago and he snaked the line and used a fiber optic camera to check the lines. There was some build up in the lines, so he used a motorized plumbing auger to clean out the inside of the pipe. He ran a camera down again and the pipe looked a lot better.
So about two weeks later I start having some flushing problems, so after plunging didn't fix it, I called the plumber back (through my home warranty company)
He was able to see a blockage of poop and toilet paper. He was able to use the snake and wash the rest of it down, the pipe looked ok inside afterwards from his camera.
So my plumber is recommending a pressure assisted toilet. To force everything down and help break it up so it won't stick to the pipe.
Anyone have any advice with build up in old cast / iron pipes or have experience with high pressure toilets?
The current toilet is a sterling 1.6 gpf bowl / with it appears a replacement 1.2 gpf tanks (with a styrofoam insert).
Not sure if I should try taking the styrofoam out or should get traditional Gravity flush toilet with a high MaP Flush Score, or if i should go with a high pressure flush toilet.
Any help would be greatly appreciated.
Thanks,
Jeff
Thanks,
Jeff
