soutthpaw07
Hi I think I have sediment causing low pressure in my hot water pipe for one of my showers/bathtub because the hot water pressure is low coming out of the bath spout and showerhead for only this one shower/bath. It started after I replaced the shower cartridge for stiff and squeaky shower handle (there's only 1 handle that controls the hot and cold water) and then turned the main water back on and then the squeaky stiff handle problem was solved but now I had low hot water pressure. I replaced the Cartridge thinking it was plugged causing restricted hot water flow but that didn't fix the problem. I had never flushed my hot water heater so I think it is probably sediment thats blocking the hot water pipe when I turned the water main back on too quickly and it shot sediment into the hot water pipe. The hot water heater was 15 years old and was going out because the hot water was lasting less and less time so the hot water was probably full of a lot of sediment. The hot water heater was replaced but it still didn't correct the issue and I still have low hot water pressure from only this one shower/bath. I was reading online to use air compressor to blow out the line because sediment could be restricting the hot water flow. What type of air compressor fitting do I attach to blow enough air from the compressor into the hot water opening? (after you remove the shower cartridge there's 3 holes: hot, cold, and i'm assuming the other one is for the shower because that hole has a pipe inside it that goes toward the shower headl). I want to blow air from an air compressor into the hot water hole but after the opening the hot water pipe makes a bend so is there some type of special compressor fitting I need to get enough air pressure to blow out sediment that's probably causing low hot water pressure?
Thanks! would really appreciate the advice.
-Morgan
-Morgan
