I'm not sure what sizes you mean? Do you mean the size of the hose to attach to the sprayer?
From what I understand, the fitting on the supply line coming directly out of the floor or wall (whichever style you have) is generally 3/8". The initial supply hose has two female ends (one 3/8" and the other 7/8" to 1/2").
The toilet and bidet lines are usually 7/8". I read somewhere that the difference between the 7/8 and 15/16 is the taper of the threads rather than size, but that they were compatible (although washers/gaskets and teflon tape were recommended).
Are you saying that you already purchased a sprayer? If so, read the specifications and it should tell you what size it requires (keeping in mind that you an use both 15/16 and 7/8 interchangeably). Some sprayers are 7/8 while others are 1/2. If you have a 1/2 sprayer, you can buy a little plastic adapter that would be 7/8" Male to 1/2" Female. You would twist it on to the bidet sprayer and then twist the hose on to the adapter. Some adapters even come with little sediment filters.
with filter
https://www.amazon.com/dp/B012DVNGWC/?tag=skimlinks_replacement-20
without filter
https://www.amazon.com/dp/B00SLSRW8Q/?tag=skimlinks_replacement-20
You might want to check a local store for the adapters though.
The order of connection goes:
*Supply line shutoff 3/8
*Supply hose F 3/8 to F 7/8 (sometimes called 15/16) or M 1/2
*T-adapter M 7/8 attaching to the supply line on the bottom
*Side M 7/8 to attach hose for sprayer
*Hose F 7/8 (15/16) on both ends or 1/2
*Top of T-adapter hooks to toilet which is M 7/8 or M 1/2
If you order one of the kits, the sprayer should probably be the right size for the hose (7/8
/ 15/16).
If you aren't certain about the size of your sprayer's threaded end and can't find it in the specs, take it with you to HD and go to the plumbing section to find the shower/toilet supply line hoses and see which ones fit.
I hope this helps.
