Quantcast
BHS Pex - Heard of it?
kf30tn
Jun 24, 2020
10
Nashville, tn
I'm looking to run a 1,200ft supply line to my house and am researching brands and costs. I have found a brand on Amazon and a website called BHS Pex. The cost is much lower but I can't find any information on the brand other than the info given by the listing/selling website. Has anyone heard of or used it? Below are some links and info for reference (sorry if needs to be taken off).
BHS Pex
Badger-pipe.com - 1 1/2" Non-Oxygen Barrier Pex Tubing
OD 1.625
ID 1.244
WALL THICKNESS .19
WEIGHT PER FOOT .35
ASTM 876/877
NOT TO BE INSTALLED IN DIRECT SUNLIGHT
MADE TO ASTM SPECIFICATIONS.
RATED AT 100 PSI AT 180 DEGREES.
RATED AT 80 PSI AT 200 DEGREES.
RATED AT 160 PSI AT 73 DEGREES.
TYPE B PEX IS MADE USING THE SILANE METHOD (WATER BATH).
breplum
Professional
Professional
Nov 14, 2017
635
226
Lafayette, CA
Not a name brand, so likely a one-of importer. No warranty, so it is all on you.
Major American suppliers will be a better bet for the long run. Though underground outdoors is not that typical a use.
Uponor PEX, when used with Uponor fittings have a 25 yr. warranty.
Polybuteleyne or Sch 80 PVC are good bets.
Mitchell-DIY-Guy
Oct 16, 2019
228
66
North Carolina
For what it's worth, I bought what seems to be unbranded, oxygen-barrier PEX about 10 years ago. I cannot even tell you where I got it. May have come from Supply House, or eBay, or Amazon. It was the ⅝" variety. It worked fine. Never an issue.
Oh, yeah--it was over 1,200 feet buried in concrete as part of a heated driveway. I sold the home last year, but didn't give an issue during install, during testing, or the 10 years I owned it.
