sarg
The price is certainly impressive ......... there goes the stimulus check.
Yes I noticed that as well twice the price of supply house. Sometimes you can find some incredible deals on Amazon and other times you run into situations like this.Not bad ..... I looked at Amazon ..... they want half a kidney.
So basically all my valves are likely leaking, just some not visible beyond the point of getting green deposits (I touched them all, not wet at all). The ones showing water were super-slow. The one I found today has formed a single drop and not even leaked below in 10 hrs yet.The green crud might just be super slow leaks from the compression nut not being cranked down tight enough during installation.
Thank you! Don't the new Dahl valves come with new compression nuts & ferrules? Why would I want to re-use the old nuts & ferrules?That green crud probably formed in the first few months after installation.
Most often, a tiny slow leak will seal itself up after awhile, minerals will plug up the gap.
It might start again if the valve gets jostled around while operating it, or changing flex hoses, etc.
The new valves should be easy to change.
There might be at least four options to mount them.
Option 1, try to reuse the old compression nut and brass ferrule, if they are compatible.
Clean up mineral crud first.
Option 2, use a puller to slide off the old compression nut and ferrule.
You can find these online, or tinker one together.
I have even used just a big crescent wrench set to a whisker wider than the pipe, and swung the wrench from the backside, to gradually tap off the ferrule.
Option 3, VERY carefully cut off the old ferrule by neatly sawing through it, without gouging up the copper pipe.
You can usually put the new ferrule into a fresh spot for a cleaner grab.
Maybe trim the copper stub a half inch or so.
Option 4, just cut the copper pipe stub shorter, removing the section with the ferrule stuck on it.
This only works if you have pretty generous stub length.
