Backing Up Washer Drain
Any idea what the flow rate may be from the hose?
If you could throttle down the flow to a point where it doesn't back up and time that flow in a 5 gallon bucket, you'd have a good idea as to what that drain system can handle and whether it's realistic to think the washer cold be throttled down to that flow rate.
Sure sounds like a problem with the drain line.
