The existing washer standpipe, picture below, is not vented. The wall sink to be added will be left of the standpipe. The standpipe P trap is to the right. I plan to use a AAV to vent the sink. After the sink P trap I think I will run the sink drain outside the wall until I get past the washer P trap, then tie into the drain with a sweeping Y. Also, should I add a AAV above the standpipe? If anyone has other suggestions, please post.
