ABS vs PVC
Discussion in 'Plumbing Products' started by WyrTwister, Feb 4, 2019.
  1. Feb 4, 2019 #1
    WyrTwister
    WyrTwister
    WyrTwister
    Dec 6, 2015
    136
    13
    Was watching a YouTube video of a couple building a house, I think in Idaho .
    They stated their code required ABS for drain and they could use PVC ( white ) for vent , I think .
    Around here , it is either cast iron or PVC . Never see ABS .
    What would the reason be for requiring ABS ?
    Thanks , :)
    Wyr
    God bless
  2. Feb 8, 2019 #2
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,384
    242
    North Reading, Mass.
    After reviewing the differences, the only reason I could find AGAINST the ABS was the fact that it is more flammable.
    In the Mid West the ABS black stuff was outlawed years ago because of fire safety issues. In a fire they found that the PVC would only smoulder and never really light up, but the Black ABS would light up like a log and burn for a long time adding to the fire.
    As far as REQUIRING ABS, the only reason I could find was that it has a higher impact strength than PVC, especially at lower temperatures.
    Check your local codes, as well as availability and cost of each.
  3. Feb 11, 2019 #3
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    around here we do not use abs because it sags
    the code calls for a support every 4' on plastic pipe
    abs needs a support every 2' in this heat
  4. Feb 11, 2019 #4
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,384
    242
    Where's here? I assume a fairly hot climate.
  5. Feb 11, 2019 #5
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    Diehard likes this.
  6. Feb 12, 2019 #6
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,278
    1,294
    Southern California,
    All you are missing is the banjo boy from the movie "Deliverance"!
  7. Feb 12, 2019 #7
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,312
    he is tied up in the front of the boat
    Diehard likes this.
Share This Page
