45 elbow crack - ejector pump
Rameez Hasan
May 14, 2019
Round Lake, IL
Hey folks, new to the forums and noob to the plumbing. However, I can handle basic to moderate DIY myself. Plumbing is risky so I need some advice on best way to fix this.
There's a 45 elbow that cracked and now leaking water. Not severe so far, just drops but could get worst if meft un fixed. I am also attaching some pictures that will give you an idea on what exactly it is.
Again, noob to the plumbing so please dumb it down for me if possible.
Any help would be greatly appreciated.
Thanks
View media item 795
View media item 794
CT18
Apr 30, 2014
619
153
Bloomfield Hills, Michigan
You could get yourself PVC glue and cleaner, 2 couplings, a 45° and a few feet of pipe. Build the replacement before you cut the old one out and also turn off pump before cutting out the cracked fitting. Place the new one up against the broken one and mark the ends of the pipe and then cut it out. The couplings will have a pipe stop in them so cut a hair more off the old pipe
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,791
262
Boston, Massachusetts
I don't see any hangers on that line in question you gotta secure it to the wall so it cant move when the pump comes on or the check valve closes
frodo
Just call me Macgyver
Professional
Supporting Member
Sep 28, 2014
8,120
2,575
I looks to me like the vertical line from the pit to that 45 is leaning a good bit
this is putting a strain on that 45 degree fitting.
maybe that caused it to crack, maybe not
the vertical needs to be plumb
and as Mr Geofd said, It needs to be strapped to the wall
I personally, would have used a pressure 45 degree fitting at that location instead of a dwv 45 degree fitting
but that is just a preference thang
Diehard
Aug 19, 2017
2,640
469
North Reading, Mass.
I believe the OP had a question in post #3. He may have been thinking about that strain on that 45 deg fitting when he thought about using rubber couplings with a clamps. ;):eek:
frodo
Professional
Supporting Member
Sep 28, 2014
8,120
2,575
thank you, I disagree he was ''thinking about that strain''
he clearly was thinking about a ham sandwich on rye with honey mustard and some Frito's
not real clear on the type of drink
WyrTwister
Dec 6, 2015
149
14
Pretty much what I was thinking , but you worded it much better than I would have . :)
Easy fix . Think they make repair couplings w/o the stop in the middle ?
Wyr
God bless
