1960's era Speakman-Kent Shower Valves
Bri
Nov 15, 2018
6
Albion, NY
I have a 1960's Speakman-Kent Shower Valve as detailed in the following link http://notthisoldhouse.blogspot.com/2011/01/1960s-era-speakman-kent-shower-valves.html
I have tried to remove both the hot and cold shower stems but there is something stopping them being removed after I have unscrewed them all the way. They are loose but cannot be removed. I have applied a lot of force to see if I can pull them out but it hasn't worked. Any ideas?
ExtraMilePlumbing
Aug 21, 2014
512
87
images aren't loading up,sounds a lot simpler to just open wall and replace valve
Jamesplumbing06
Feb 24, 2016
552
112
So your fixed by your description on photo. But they have new dress up kits for those. Flipping seal over will create a emergency one night at the end of a shower. Please retrieve a new stem and seal. Good that you got seat replaced. That’s 90% of your leak.
Bri
Nov 15, 2018
6
Albion, NY
No I'm not fixed, I cannot get the stems out, they unscrew all the way but there seems to be something at the end of the stem , inside the valve, stopping the stem coming out. I have new stems to fit but can't fit them obviously.
Jamesplumbing06
Feb 24, 2016
552
112
o sry read it wrong. The first hex nut is just a stem seal nut. (Packing nut)These older 3 handles were mostly tiled tight. Anytime the valve has never been broken loose. I have to expand hole to get to to next hex nut. The center tub diverter. Is more a pain. Mark maximum hole size with existing chrome ring (euchuteon) then a diamond dremel. We aren’t opening up wall. Just making room for socket to get into hex fitting on valve.
I keep going back to that link. There is someone explaining that it’s fixed and ready so I little confused. The pictures show front of steam. Do you have stem sockets?
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,691
252
Boston, Massachusetts
when you remove the stem with the water off open the stems half way then back it out....try vinegar or clr to loosen things up
ExtraMilePlumbing
Aug 21, 2014
512
87
take off the handle/grind it off if needed to create access to the hex nut in wall then use hex tool to unthreat
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,691
252
if your wondering how to remove the nut behind the tile there are (sockets) at hd or lowes /any hardware store has in the plumbing section after removing that the stem should thread out
Geofd
Staff member
Professional
Supporting Member
Jan 20, 2018
1,691
252
sometimes theyare refered to as cowbells... once you see them you will know why
Group Builder
