F faucetman New Member Joined Feb 26, 2017 Messages 1 Reaction score 0 Location , Feb 26, 2017 #1 Hi All, Any suggestions on how to replace these faucet knobs, with minimal to no damage/alteration to the tiles? Thanks for any tips.
T tanksnotanks Well-Known Member Joined Oct 6, 2016 Messages 91 Reaction score 18 Location , Feb 27, 2017 #2 Nope,looks like tile damage to me
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Feb 27, 2017 #3 easy. cut the wall behind the valve, remove the trim from valve remove the valve from the back, insert new valve into old holes replumb, test, caulk, patch sheet rock in bedroom/closet/hallway/whereever it is
T tanksnotanks Well-Known Member Joined Oct 6, 2016 Messages 91 Reaction score 18 Location , Feb 27, 2017 #4 Of course you could do it from the back if you have access but why would you replace it with the same configuration
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Feb 27, 2017 #5 why? to keep from forking out 2 g's for a new tile shower, the op did not ask my opinion if i liked it or not, asked how to do it with no damage to tile Last edited: Feb 27, 2017
T tanksnotanks Well-Known Member Joined Oct 6, 2016 Messages 91 Reaction score 18 Location , Feb 27, 2017 #6 Won't be up to code with that configuration
S SHR Member Professional Joined Mar 5, 2014 Messages 646 Reaction score 296 Location , Minnesota Feb 27, 2017 #7 Can be, if it is installed correctly with a separate pressure balancing valve.
frodo Just call me Macgyver Professional Supporting Member Joined Sep 28, 2014 Messages 8,578 Reaction score 2,976 Location right here right now, over there later on. Feb 28, 2017 #8 code violation ? which one ? i have never seen anything in the code that tells you where to put your handles. except handicap,,,that is clearly not handicap
T tanksnotanks Well-Known Member Joined Oct 6, 2016 Messages 91 Reaction score 18 Location , Feb 28, 2017 #9 In the configuration it is in now it does not have a pressure balance valve to keep from getting scalded In my jurisdiction I cannot replace it with a non conforming valve
Mr_David Easily Amused Professional Joined Jan 11, 2010 Messages 4,170 Reaction score 1,061 Location Santee,Ca, Feb 28, 2017 #10 What's stopping you from installing a 2 handle pressure balanced valve? 8" Centerspread Shower and Tub Faucet_KB661AL They are only $350 a pair
