Please let me post the parameter as below:Looks bulky and heavy
the upper picture ,Battery Powered Fitting Tool .
Clamping force:20KN
Clamping range:12-40mm
Stroke:40mm
Connecting/Charge:320times
Working cycle:3-10s
Voltage:18V
Capacity:3.0Ah
Charging time:2hours
Package:Steel case
ACCESSORIESies: 12, 16, 20, 32, 25-40mm2
Battery:2pc
Charger:1pc
Sealing ring of cylinder:1set
Sealing ring of safety valve:1set
Package weight:13 kg
NW.:10 kg
AQualityPlumber said:By far the best pex system out is uponor wirsbo. The best thing about it is Milwaukee makes all the expansion tools now. Even a small 12v compact. All operate on standard Milwaukee battery's. Go check it out.
cjn79 said:Agreed. Milwaukee is where it's at. Great tool. My next choice is the watts cinch clamps then wirsbo.
Sry my 3yr old hit send on my ipod. The wirsbo tool is what I meant to say. Milwaukee 12v is best for wirsbo. But I like watts and the cinch clamps. No leaks with the wirsbo but have had few with the watts.
phishfood said:Can you expand upon the bolded part of your post? What kind of leaks, what do you think caused them?
Net Weight -- 10kg (22lbs) for the tool.
