Hello. I am new here. Posting to ask about an issue I am having. I am not a pro just a DIY guy who likes to learn.
Question: I have a posi-temp moen single-handle shower system with no balancing valve. Uses a Moen 1222 cart. The tub spout had a constant small drip/stream of water coming from the tub spout.
I took out the Moen 1222 cartridge replaced it, and lubed it up pretty well. I also replaced the tub spot out of caution. After those two replacements, the tub still leaks from the tub spout. Also, the roof started to leak below the shower after the replacements when the shower was turned on.....I took off the tub spout and the water runs out slowly through the copper pipe.
I checked the meter and it shows no running water or leak. So any advice on this issue would be greatly appreciated.
Thank you for your time.
SRD
SRD
