3/4" hose big and 3/4" ball valve wrench size
1j5aooo
Mar 26, 2016
5
Do you know what size wrench I woud need for the 3/4" ball valve and the 3/4 hose bib. Measures around the nut part of aprox 31.25mm (1.23") for ball valve and 27.38 mm for the hose bib, 3/4" itself comes out to 19.05 mm, Second time lost / stolen wrench, of my resuructing my 3/4" febco, of a crecent that appared to fit and I forot the size of the hose bib wrench I was using. Pipe appears to strip and slip, as it has a lot of wear as well as the adjustable.
My good American made adjustable wrenches never give me an issue. One of my favorite is a 15" proto.
  • Like
Reactions: SHR
th
What size non adjustable wrench Do I need, 12" Trucraft, Boom Adjustable stripped itself and everything else it came into contact w/ light or the dammn "Bib". 14" 1/2-1 1/2" pipe Shick stripped!!!!, (but works w/ electrical tape somewhat looses grip). A lot of plumbers even w/ the American Adjustable Wrench's put all lot wear and strip onto it as well.
What size non adjustable wrench Do I need, 12" Trucraft, Boom Adjustable stripped itself and everything else it came into contact w/ light or the dammn "Bib". 14" 1/2-1 1/2" pipe Shick stripped!!!!, (but works w/ electrical tape somewhat looses grip). A lot of plumbers even w/ the American Adjustable Wrench put all lot wear and strip onto it as well.
You need a minimum of a 15" adjustable wrench (MAX OPENING 2") for most home plumbing needs (IMO).
Buy QUALITY, not off-shore junk. CRAFTSMAN at the least.
Most rounded off hex heads are from using either a set of slip joint pliers or a pipe wrench.
A man is only as good as his tool... :D
They have Husky at home depot, and Tawiaan brand at Harbour freight. The husky appears to be very heavy and solid as wel. Alittle larger than 15" I believe and some more that were the mini's about 8". I think I'll just stick to my old wrench's and give them a few coating of grip after I clean them up, appears to be for me, after I had cleaned them up, but may opt for a larger size or socket, if I have any more trouble.
