Figures !
What are they using to regulate pressure after the meter? Only that regulator “in-lime” after the meter.
Well that would suck even more. Would think “city” pressure has to be higher than 65psi?!
Check your pressure immediately before and immediately after your new filter setup.
it could be your new gear.
Might be that check valve going bad.
37 psi with two showers running may be all you’ll get.
65 psi is fine. Sounds like your volume is restricted. Check valves can and will absolutely restrict volume, especially when the go bad.....
Plus you have all that filter gear restricting flow.
Best way to check the check valve? Can I by-pass and see what happens (good/bad idea)?
If the check valve is not the cause, are there options to increase the pressure pre-meter?
I suggested a pressure gauge before and after your filter gear.
...It’s probably your filter gear restricting volume. Was there a problem with pressure or volume before you installed the filter gear ?
Could be that backflow preventer. I’ve had them do it before.
(side-note edit: called the Township W&S authority who told me: pre-meter pressures can range from 25psi to 90psi! Seems like a "We don't have to care, we're the Water Company" kind of answer! ))
Sounds like your volume is being restricted by the filter gear.
There’s a relationship between volume and pressure. You can have good static pressure and low flow.
