Hello all, I hope someone here has some advice for me. I have cattle in the field and corral, and I depend on two yard hydrants to water them. I'm suddenly having problems with both hydrants!
#1
I have a Merrill Mfg C-1000 yard hydrant at the corral, that's apparently freezing up. It's buried 3' in the ground (we are in Missouri). It developed a leak at the nozzle a month or so ago, and I replaced the plunger and packing nut. Worked fine, though a bit stiff. Come freezing weather, and it's stuck. I can raise the handle only part way, but no more. Once it warms up, it's fine. I adjusted the packing nut a bit looser and it operates easily, but then cold weather came and once again, stuck. I can't loosen the packing nut any more or it starts to leak. There is some play, or wiggle, in the standpipe, about 1/2" - so I suspect frigid air is getting into the hole. I see no evidence of ground seepage, so I don't think it's leaking from the plunger or underground anywhere. I'm a retired homemaker and did not install this thing, but I need it and must fix it myself.
Do I need to adjust the pivot connector and nuts (up? or down?)?
Is there something interfering with the plunger at the bottom? (Like gravel not installed correctly?)
Is the simplest fix just to widen and then backfill the hole tighter? How do I keep debris/dirt from getting into the plunger area?
Is it a dumb idea to just wrap heat tape around the standpipe and pack some dirt down around the standpipe?
#2
This one is a Pro Plumber brand, keeps a water tank filled for the pasture cattle. It operates just fine, cold or warm - but we have an underground leak somewhere. The whole area just south (slightly downhill) from the hydrant is a swamp and remains muddy even in drought conditions. I have a buddy coming this week with his ditch digger to investigate and fix this thing.
Prior to digging the damn thing up and possibly chasing water lines and connections, is there a simple adjustment on the hydrant I should be looking at? It has just one nut, I believe the packing nut.
Thank you for anything you can advise.
#1
#2
