Wondering who can solve this one...
Discussion in 'Drain and Sewer Cleaning' started by Dana M., Jul 19, 2019.
  1. Jul 19, 2019 #1
    Dana M.
    Dana M.
    Dana M.
    Jul 19, 2019
    5
    Sacramento, Ca
    8866FA1C-B3C6-44A9-A58C-ED2529622F54.jpeg So my kitchen sink (which is a stainless basin style single drain with disposal and dishwasher tied in) is plugged. I’m by no means a plumber but have my fair share of plumbing experience. I’ve tried clamping dishwasher drain and plunging, hot water, removing disposal, checking trap, all with no luck. The only way sink or dishwasher will drain is by running disposal, which I know can act like a pump to push water trough a blockage without clearing it, so I figure the blockage is downstream of the trap. So I have a cleanout directly below the trap, so I think, perfect, open the trap to snake out the clog, only when I pull the cap, 1 1/2” inside the cleanout is a solid plastic, almost like a knockout blocking the cleanout from being cleaned out. And here lies my dilemma. Anybody with some solutions? Oh yeah, this is my first post, so if I’m out of turn or in the wrong forum or whatever, I’ll apologize now. Thanks for your help.
  2. Jul 19, 2019 #2
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    118
    16
    Chicago suburbs
    Pictures please.
  3. Jul 19, 2019 #3
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,314
    1,309
    Southern California,
    Put your finger in the clean out and see if you can feel for a hole that shoots downwards.
  4. Jul 19, 2019 #4
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    118
    16
    Chicago suburbs
    She said!
    Haha!
    Sorry, low hanging fruit!
    Rickyman and Mikey like this.
  5. Jul 19, 2019 #5
    Dana M.
    Dana M.
    Dana M.
    Jul 19, 2019
    5
    Sacramento, Ca
    So when I insert my digit all kinds of crazy things happen, non leading to a downward facing hole. Sorry, couldn’t help it. I attached a picture. It is blocked solid, I know it’s not supposed to be, last night I drilled a 3/16” hole through that plug or whatever it is and there was water behind it, so I stopped and tightly replaced the cleanout cap.
  6. Jul 20, 2019 #6
    Jeff Handy
    Jeff Handy
    Jeff Handy
    Jul 5, 2019
    118
    16
    Chicago suburbs
    Maybe that thing is some kind of cheater air vent, to fix a bad venting situation?
    Your pic is pretty vague, blurry, no scale or sense of where that stuff is in the sink cabinet.
    Just saying.
  7. Jul 20, 2019 #7
    Dana M.
    Dana M.
    Dana M.
    Jul 19, 2019
    5
    Sacramento, Ca
    I hear ya on the picture, it’s a normal size kitchen cleanout, about 8” directly below where the sink drain goes into the wall. When you push on it it will definitely flex, not what you would expect from abs. It’s almost like a scrap piece or something that didn’t get cleaned off the mold, and then whoever installed it didn’t see it. Oh yeah and this house is only a year old
  8. Jul 20, 2019 #8
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    242
    38
    Northwest Washington
    Sounds like it's time to open up a wall, either under the sink or behind it, and see what's really going on. If it was only built a year ago, you might get lucky and find plans (check your local building department), but I wouldn't bet on it.
  9. Jul 20, 2019 #9
    Clickyfri
    Clickyfri
    Clickyfri
    Aug 11, 2018
    7
    Pittsburgh, pa
    Can you remove the trap and try snaking it through there instead?
  10. Jul 20, 2019 #10
    Dana M.
    Dana M.
    Dana M.
    Jul 19, 2019
    5
    Sacramento, Ca
    I started to try and go through the trap but it makes a sharp turn up or down( probably a tee) right after it goes into the wall. So I figured just go through the clean out, which was convenient and seemed much easier until I opened it up and found there’s no way to get into the cleanout and it’s the only cleanout in the house.
  11. Jul 21, 2019 #11
    CT18
    CT18
    CT18
    Apr 30, 2014
    512
    126
    Bloomfield Hills, Michigan
    Can you get a light under there and then take some pic. Get pics with it all assembled and then take the cleanout cap off. Need to have a better view of inside that cleanout tee
  12. Jul 25, 2019 #12
    Dana M.
    Dana M.
    Dana M.
    Jul 19, 2019
    5
    Sacramento, Ca
    So to update, I hired a REAL plumber instead of messing around with this anymore. I hadn’t finished my sentence when he already had an answer and a fix for me. The “blockage” in the clean out was a “ test plug” left in by the builder, it just didn’t have the customary screw and wingnut that I’m used to seeing. He broke it out, snaked the drain to the main and was cleaned up and telling fish stories in 30 minutes. I thought he was more than fairly priced as well. I’m a big supporter of DIY, but rather than getting in over your head or chasing ghosts with money, call a real tradesman that know what he/she is talking about. Money well spent in my book.
  13. Jul 25, 2019 #13
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    242
    38
    Very well spent. I'd be embarrassed I didn't think of that, except that I've never touched one of those plugs in my life. Maybe the builder would be kind enough to pick up the tab.
Share This Page
