I had my bathroom renovated many years ago and the when the contractor installed the ABS under the sink he didn't use a P-trap. I'm assuming this is for one of two reasons:
1) It was easier to forgo using a P-trap in lieu of getting the job done quicker/easier
2) There wasn't enough of an offset for a P-trap to fit
For the sake of everyday use, it has virtually no impact. However, for One, I'm not sure it's technically legal not to have one (P-traps prevent gases from entering the home). For Two, it makes it impossible to clean out any gunk buildup that may be inhibiting water flow. There's nothing to keep a drain cleaner from going straight down the pipe instead of stopping at the P-trap and being allowed to "sit" and break down the buildup. Plus, that stuff smells pretty nasty and attracts drain flies. I'd like to please get the opinion of some pros (see pics). I know P-traps are adjustable to a point but I suspect there may still not be enough room to accommodate the limited offset of the piping. Are there enough parts available (elbows of varying degrees, etc) that would make it possible?
