yeto
Will the following interchange/fit (20mm To 20mm PVC Ball Valve Union Joint Slip Shut Valve PVC Pipe Fittings Plumbing For 20mm Outside Diameter's Pipe Water Pipe) 3/4 inch PVC pipe?
Thank you,
yeto
Thank you,
yeto
20mm is .787 inches of 25/3220mm is 1/2'' correct?
