[Edit: For an above-ground comparison, if I take a chainsaw and let it bounce up and down on a branch it will take 10 or 20 times the time to cut thru the branch, and it won't be a clean cut. Some drain cutters mostly bounce around. Serrated cutters could operate like a chainsaw moving in a circle if they were on a flexible guide skid - like some inspection cameras. Would that not make the cutter more like a chainsaw with a consistent path - vs a bouncing chainsaw - and thus more effective?]
If drain augers had wheels that kept the cable centered, I'd trust cutters won't "bounce" around and smash clay pipes.
Can you add wheels to a drain augur cable to keep it centered? I found various products with names like "flexible skid guide" - all meant for cameras, except one that costs over $5000 ("RAPTOR NOZZLE (FLEXIBLE GUIDE SKID)"), but it's a hydro-jetter - it doesn't use a rotating cable.
Here's one that's $200 on alibaba, around $150 USD - for cameras. A rotating cable could not be inserted.
Why can't I buy a skid guide for a rotating-cable drain auger?
