What tool to hold on to these brass fittings?
LilyT
Aug 13, 2018
101
7
98007
I'd like to unscrew the two fittings apart:
the left one is a 1" barb x 3/4" male MPT - the surface got marred by my tongue & groove plier.
the right one is a 3/4" female FPT x 3/4" female FPT - this one has 2 ridges.
Are there some special tools to hold on to these fittings?
I probably found the answer to my own question - pipe wrench!
And or (in conjunction with) vice grips...
Thank you very much for the suggestion!
It’s funny, I do have a 9” long nose vice grip lying around in my toolbox, however, I have never figured out how to use it. Now after seeing your suggestion, I searched for and finally learned its proper usage.
Thanks for your suggestion! The tongue and groove plier I used looks like knipex. It slipped though. Maybe it’s because the jaw of my plier is not round enough like Hamberg suggested.
Knipex is a name brand of tools ......
They make everything from screwdrivers to bolt cutters 🤣 They make pipe pliers and all kinds of high dollar toolZ.
You can go to Walmart and buy two cheap pipe wrenches and be set for life LilyT 🎊
I see. I was looking at Harbor Freight for cheap tools, I didn't know Walmart carries them too. Thanks!
Harbor freight is fine too.
I have a $20 Harbor Freight torque wrench thats just as accurate as my $250 Snap-on torque wrench.
To be fair even with good tools sometimes a little heat works wonders at assisting loosening parts.👍
Word of warning about Harbor Freight vice grips. My son has a pair that came with an extensive tool set which was made with such soft metal that when it was used to apply a lot of torque to a pipe it deformed. Now the lower jaw is displaced back half an inch from the upper one. That set was pretty flimsy actually, a couple of the sockets also deformed. The 3/8" to 1/4" socket adapter also sheared off, but I've done that too with a Craftsman adapter too - that little 1/4" post cannot take much torque.
On the other hand, HF plumber's wrenches are quite sturdy.
