M Byley New Member Joined Aug 14, 2023 Messages 4 Reaction score 0 Aug 15, 2023 #1 I don't know what's up with this corroded looking tub drain. It doesn't appear to have any threads so it can't be removed with the usual methods. The tub doesn't hold water. 90's era starter home. Thanks .
breplum Professional Professional Joined Nov 14, 2017 Messages 2,364 Reaction score 1,200 Location Lafayette, CA Aug 16, 2023 #2 rotted out metal. probably bad water conditions. a plumber can remove it or replace the assembly
M Byley New Member Joined Aug 14, 2023 Messages 4 Reaction score 0 Aug 16, 2023 #3 breplum said: rotted out metal. probably bad water conditions. a plumber can remove it or replace the assembly Click to expand... Thank you.
R RickFlorida Well-Known Member Joined Sep 8, 2020 Messages 258 Reaction score 44 Location USA Sep 11, 2023 #4 I'd get that out of there before a large piece of it falls into your pipe and causes more problems. Should be easy to remove and replace.
