pasadena_commut
We have a 3/4" brass ball valve T'd off of our new water line which will be used soon (as in weeks, not days) for the irrigation system. Right now though one end is just waving around in the air, completely exposed. I want to screw a plug into the exposed opening to keep dirt out of it, and also to stop possible water flow if the gardeners or somebody/something else bumps the handle. I'm not sure what sort of threads are on the valve, probably NPT. The valve is stamped with 60W006, or maybe 60W00G, there is other text on the bottom but I couldn't find a mirror just now to read it and the handle print is too small for me to read.
If the threads on the valve are NPT, as sees likely, would this work?
https://www.homedepot.com/p/LASCO-Fittings-3-4-in-PVC-Schedule-40-MPT-Plug-450007BC/317626846
