What Materials Are Best For Kitchen Sinks?
Discussion in 'General Plumbing Help' started by Hammer, Apr 22, 2019.
  1. Apr 22, 2019 #1
    Hammer
    Hammer
    Hammer
    Sep 29, 2017
    10
    Solid Surface Sinks, Acrylic, Stainless Steel
    Budget $300
    Thanks
  2. Apr 22, 2019 #2
    phishfood
    phishfood
    phishfood
    Moderator Staff Member Professional Supporting Member
    Jan 18, 2010
    5,769
    991
    Orlando, FL
    In your price range, I would stick with stainless. You should be able to get a decent gauge stainless for that, unless you are going for something really wild.
  3. Apr 22, 2019 #3
    Matt30
    Matt30
    Matt30
    Professional Professional
    Jan 17, 2012
    2,077
    805
    Halifax, Nova Scotia
    $300 would allow for a decent stainless sink and cheap faucet
    Hammer likes this.
  4. Apr 22, 2019 #4
    FishScreener
    FishScreener
    FishScreener
    Aug 23, 2018
    237
    67
    83467
    Be sure to check Habitat For Humanities outlet store if you have one near you. I picked up a couple of very nice Koehler cast iron units for $35/each.
    Other than that I’d say go with the stainless, and $30 worth of sound deadening sheet makes a huge difference in how nice an inexpensive sink sounds, and a bit of spray foam sure helps it hold the heat longer.
  5. Apr 22, 2019 #5
    Hammer
    Hammer
    Hammer
    Sep 29, 2017
    10
    Thanks, what is decent gauge for stainless?
  6. Apr 22, 2019 #6
    Hammer
    Hammer
    Hammer
    Sep 29, 2017
    10
    I'm unfamiliar with sound deadening for sinks.
  7. Apr 23, 2019 #7
    havasu
    havasu
    havasu
    Jan 6, 2010
    9,235
    1,282
    Southern California,
    The higher end stainless sinks have a thin membrane of self stick rubber on the underside to help mitigate the sounds from the sink.
    Hammer likes this.
  8. Apr 24, 2019 #8
    packardv8
    packardv8
    packardv8
    Jun 4, 2014
    23
    5
    The OP didn't define his/her terms sufficiently to receive a meaningful answer. What are the prime directives?
    1. Fit within the existing cut out?
    2. Durability?
    3. Style?
    4. Choice of colors/finishes?
    5. Single, double or 1/3-2/3?
    6. In-stock-big-box or custom order
    7. Since faucets were not specifically mentioned, it should be assumed the $300 budget allows for a wider choice of sink?
    jack vines
  9. Apr 24, 2019 #9
    Hammer
    Hammer
    Hammer
    Sep 29, 2017
    10
    1. Fit within the existing cut out? - No
    2. Durability? - Yes
    3. Style? - No
    4. Choice of colors/finishes? - No
    5. Single, double or 1/3-2/3? - Single
    6. In-stock-big-box or custom order - Either works
    $300 is the budget for the sink only
Share This Page
