Hello,
I'm new to DIY plumbing projects.
I disconnected the dishwasher (i'm assuming from a hot water inlet under the sink) because we never use it, and I added a 3/8" to 1/2" connector tube that I bought at the home depot to set up my sink style clothes washer to connect to the sink inlets instead of screwing in to the sink faucet. The picture does not show this (pre the first step described above with dishwasher inlet connector still connected)
There is a 4th inlet under the sink. It is upside down. I tried screwing in a 3/8" connector but it seems to be too small.
Any tips on what size this is? Could it be that it is missing some adapter piece and this is just a knob that an adapter has to be screwed in to?
It is facing down and the rest are facing up.... Does this mean something?
Please tell me it isn't a gas inlet...
I was hoping the inlet on the bottom left was hot water (washer was hooked to this one) and I was hoping that the bottom right was cold water...
First post, thanks in advance!
EDIT: the second photo shows the 4th inlet up close but the resolution / flash blow-out doesn't show the threads very well. It has threads all the way up the outside of the narrow part of the inlet.
