I've got quite the puzzle on my hands! I'm no plumber, but I've asked for advice from various professionals and still no sure answer... I'm turning here for help.
When the shower is turned on, whether hot or cold, water appears at a particular spot on the drywall. I've included photos. You'll notice I've captured the moisture mid-accumulation, as it darkens the wall from top to bottom almost every time.
I've considered a variety of possibilities:
(1) Could it be the caulking? It is noticeably thicker on that side of the tub, but it is never wet. Could water be traveling behind the caulking? Is it, perhaps, the wrong kind of caulking? It looks like a DIY job.
(2) I cleaned the vent, thinking it was condensation causing the problem. At first, I was convinced I'd solved the problem. The vent was incredibly dirty and there was far less humidity while taking a hot shower. Furthermore, monitoring the area, I didn't see any dampening. Unfortunately, today I ran a cold shower, just to test it, and water began to accumulate.
(3) Could there be a pinhole leak behind the wall?
(4) Is the shower head spraying horizontally a little onto that side of the wall? I'm going to test this possibility next by placing the shower head on the floor while running the water and seeing if water accumulates in that patch.
EDIT: A few other points of interest: (1) The hot and cold handles require quite the turn to fully shut off, otherwise there is a drip from the shower head. (2) It seems, looking at the kitchen ceiling, that there has been a repair in the past, but that portion of ceiling is not wet and has not changed since moving in.
Thanks for your suggestions.
