Hello, hopefully someone can give me some insight b4 I go throwing money at this. thanks in advance!
issues- pump comes one and off about every 10-12sec when I'm running water, but only when I'm running water.
I've changed the switch didn't help
made sure the pressure in the well tank is 38psi- i have a 40/60 switch
checked the value on the tank "no water coming out with I release pressure"
also did the knock test, upper 1/4 of the tank is hollow.
system is old and I just purchased this house, so I have no prier knowledge of this system.
should I just buy a new tank and hope it solves this issue, or is there something else "cheaper" i should try?
