Finally after years of a privy and a pitcher pump...and much to the agreement of my wife and two daughters ...I put in a running water system at our little log cabin and a bath house. sytem is a combo of pex and copper. All in all things worked out well but since i did it two years ago I have one issue. Its a sand point with a shallow well pump. Pump is good up to 25 ft. Water level is twelve feet down the pipe. Did the whole system myself including driving the point. Problem im having is every once in a while ( might only happen once in a three day weekend at the cabin..sometimes 3 or 4 times just depends) when the pump kicks on because waters being used the pump will keep running. Usually when pressure drops because of use the pump kicks on in standard fashion and runs for about 30 to 40 seconds to get tank up to pressure and shuts off. But as said once in a while pump wont shut off...so then what Ive learned is i have to go to kitchen sink...turn water on...itll slowly peeter out to no water...just a trickle...with pump still running ...after about 20 to 30 seconds it starts coming back to full stream of water...while doing that it always spits very hard bursts of air, splatters everywhere...can hear gurgles in pressure tank in crawl space...once spitting is done waters back full pressure, pump shuts off and all is good until next time it happens. On rare occasion my kitchen faucet trick doesnt work i have to prime pump like im doing spring start up. Trying to get to bottom of this see if i can deal with it myself...in the spring if i cant im going to get a pro to handle it . Sorry for the long post and thanks in advance for any help.
