Howdy folks i replaced the water valve on the supply line and in the process the pipe to the valve became a bit loose so the pipe has a an inch or two of movement now if you pull on it. I dont believe it is leaking but is this a potential problem? I could cut a hole in the drywall where the toilet tank is against the wall to take a look if necessary. Thanks
