donie1
Hello everyone.
I am having a water pressure issue and the search I did on the forums doesn’t really cover my issue.
When I turn on a faucet, I have decent water pressure; however, if another faucet is turned on I lose water pressure at both. If I am upstairs taking a shower and someone turns on the faucet to rinse a dish, I can tell when it is turned on and when it is turned off. If a toilet is flushed water pressure at the faucet drops to practically nothing.
I have had a plumber out to try to figure out what is going on. He looked at the plumbing in the house and said everything looked like it should. He put a water pressure gauge on the outside faucet and it showed 100+ psi. After seeing the dramatic drop in water pressure when a faucet is on and the toilet is flushed, he though his gauge was broken and bought a new one. The new gauge also showed 100+ psi.
His thought is since the psi is greater than 80psi and there isn’t a pressure reducing valve, the high pressure might be causing something to not working right and his suggestion is to install the valve. To his credit, from the beginning he told he wasn’t very experienced in this area he wasn’t really sure what to do and hasn’t charged me for this yet. He urged me to call in another plumber for a second opinion to see if they could figure it out before installing the pressure reducing valve.
Before I called in another plumber for a second opinion, I wanted to reach out to anyone here to see if his thought process and solution makes sense or if anyone might have an idea of what is going on.
I know this was a long read, so if you made it this far, thank you.
Can anyone help me out?
