HelloFarfel
Hey there-
I've discovered that a built in bathtub in a property I own is not level. Water has been leaking out when tenant takes a shower and pools in the front corner of the tub where it meets the floor. This has resulted in water eventually leaking through the floor. I know the "proper" fix is to pull everything out, level the floor, put everything back and then re-tile but the expense of that right now is daunting. I'm wondering if it would be possible to just build a wall about one or two (4x4") tiles wide along the edge from the tub to the ceiling to keep the water in the tub. If a shower curtain is pulled all the way to the wall behind the new tiled wall it seems that would do the trick. Thoughts?
