I need to R&R my orig. (1990) home water heater. I'm located in San Bernardio County CA.
It's highly unlikely that the current copper piping from the relief valve will line up with the new water heater. By code can I keep this fix simple by cutting back the pipe about 10 inches from the relief valve and then sweat on a threaded connector. At that point use a flexible copper line directly from the relief valve to the threaded connector? Or do I have to keep it all solid copper tubing?
Thanks in advance
Thanks in advance
