Water Filter
Discussion in 'General Plumbing Help' started by rickwhoo, Apr 8, 2019.
  1. Apr 8, 2019 #1
    rickwhoo
    rickwhoo
    rickwhoo
    Jun 26, 2010
    73
    6
    My water comes from the ground with a well pump. I want to add a water filter for the purpose of keeping the sediment from clogging my aerators in my faucets. What filter system should I buy?
  2. Apr 8, 2019 #2
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,797
    2,432
    https://www.tractorsupply.com/tsc/product/water-source-well-system-sediment-filter
    This Water Source Well System Sediment Filter is used in water well applications to reduce sediment in-line for sprinkler systems and whole house systems. It also helps make pumps, well tanks, sprinkler heads, and all plumbing fixtures last longer. This filter includes a 100 mesh stainless steel screen.
    • Ideal for pre-filtration where well pumps are used
    • Filters out sand and other sediment from well or irrigation pump applications
    • Protects plumbing fixtures, washing machines, pressure tanks, small and large sprinkler heads
    • Sediment is visible through clear bowl, making it easy to know when to flush
    • Replacement filter screens are not available in store
    • Please contact manufacturer for replacement filter screens (sizes ranging from 30 mesh to 500 mesh)
    • This does not replace the need for a whole home filtration system
    • Fits 1 in. and 1-1/2 in. pipe
    rickwhoo likes this.
  3. Apr 8, 2019 #3
    rickwhoo
    rickwhoo
    rickwhoo
    Jun 26, 2010
    73
    6
    WOW! Great! I didn't think there was there was going to be something so in-expensive to get for my needs. This looks great!
  4. Apr 15, 2019 #4
    rickwhoo
    rickwhoo
    rickwhoo
    Jun 26, 2010
    73
    6
  5. Apr 15, 2019 #5
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    1,026
    217
    Mansfield,, Ohio
    That would work just as good. You can buy filters for taste, odor and sediment.
  6. Apr 15, 2019 #6
    rickwhoo
    rickwhoo
    rickwhoo
    Jun 26, 2010
    73
    6
    I only need to prevent the sediment from clogging things in my house. What micron rating should I go with? I'm seeing 50, 100, 200, 500 and 1000.
  7. Apr 16, 2019 #7
    rickwhoo
    rickwhoo
    rickwhoo
    Jun 26, 2010
    73
    6
    Where's the best place to install these filters? Before the pressure tank or after?
  8. Apr 17, 2019 #8
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    271
    47
    Northwest Washington
    After.
  9. Apr 17, 2019 #9
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,797
    2,432
    A grain of sand is anywhere from 75 to 150 microns, so a 50 micron water filter should be good enough to handle your sediment issue.
  10. Apr 18, 2019 #10
    rickwhoo
    rickwhoo
    rickwhoo
    Jun 26, 2010
    73
    6
  11. Apr 18, 2019 #11
    rickwhoo
    rickwhoo
    rickwhoo
    Jun 26, 2010
    73
    6
Draft saved Draft deleted
Share This Page
Group Builder
