Hello, I have some troubles with our septic tanks, I have not much experience with it so hope somebody can advise me.
I live in this house for 3 years, we always had a wet spot in the yard but that did not bother me or caused any problems.
A few months ago I've drilled some wooden posts into the ground to make a dog fence, now around the pole, water is being pushed up.
Today I removed the pole, and dug down to see if I could locate the source, I've dug down till I hit a layer of gravel, the smell gives away it is sewer water, the water looks clean though, the water is pushed out of the gravel layer.
Now I'm wondering though, this is what a drain is supposed to do, release the water to the ground, so would there be a problem with my line, or is the water just taking the route of the least resistance and that's why it shows up ?
If it just the route of least resistance, I thought of sealing the gravel off with a few bags of concrete to try to hold it down, but I'm kind off afraid it might be a sign of a larger problem.
Our septic tank is not cleaned in at least 10 years, so this is something I will get done anyway, is there any way they could test the drain pipes while they are at it ?
(system is ±30 years old, have no drawings of the lines)
Thanks in advance....
Mark
Mark
