AJay
Moron
Wash machine in 54 year old house currently drains into deep sink. Would like to add stand pipe in wall instead as we renovate laundry room. Was going to do this similar to the attached image. However I am not sure if the drain that goes down into the floor, which at point is a slab and not accessible in the basement, is a 2" pipe. So converting that to a 2" is not possible. Most existing drains and vents are copper with cast iron stacks. Other side of the wall is the garage so accessing piping is easy enough. Replaced the drywall on that side and didn't mud it up so will be opening that up today to check.
And if we do have 2", we intend to also keep a sink in the room. Does that drain rough-in height have to be 16".
Thanks very much.
Thanks very much.
