watercamper
Happy Holidays to all. I moved my bathtub so that I can put in a separate shower. This is a clawfoot tub with a 1.375" diameter drain.
Our Idaho code requires 3'6" for this horizontal distance between the vent and the tub. This is 1.5" drain pipe & 1.5" vent pipe, all per code. (for info, right after the Y (T?) at the vent, the pipe diameter goes to 2"). I looked at the various diagrams to determine where to measure this distance and then measured mine. I am 6" over.
What ramifications can I expect for this extended distance? My engineering mind says nothing. The tub is not allowing as much water to pass through due to it's drain size so less water flow = less need for air. Do you think an inspector would let this go? (Probably depends but I'd like your opinions).
To remedy the situation, can I re-plumb the horizontal run with 2"? (Code allows 5' for 2" diameter & a 1.5" vent. I would still have to reduce the connection down to 1.5" at the tub connection.
