mzimmers
Active Member
Unfortunately, I won't be using sprinklers (drip and bubblers). So, what's the word on running the PVC above ground up and over to a higher location?
Well, it won't be just lying on the ground -- I would attach it to the house. Straight up from the where it exits the house (in the pic) about 7-8', then about 30' to the right, where I'd put the valves, then a return down to where I've dug my stupid trench.I go up there quite a bit. Im sure your City Council would frown on seeing white plastic pipe exposed everywhere. Just a hint, what you can't bury, just cover with bags of DG, gravel, dirt or sand.
Good find this will show the op diffrent applications
Not sure what yours mean by drip downSo, if I install a valve at this lower location, but only run it downhill (to the other half of the yard), I won't have the dripdown problem, correct?
If I'm interpreting this correctly, that means that I can't put a tee in at the water source, and install two valves at different heights? Damn, doing this right isn't easy.Here is what the instructions say..."Anti-Siphon valves should always be installed at least 6 in. above the highest head on the valve line, and should never have another valve installed further down the line from the main valve."
