Vincennes26
I purchased a house recently so know noting of the installation of the shower in my ensuite There are two shower heads, each controlled by it's own 1/4 turn on/off valve but with a single mixer valve for temperature.
One of the shower heads recently started dripping. I assume the cartridge needs replacing but have had a really difficult time identifying the maker of the valves (the shower head says Moen but I know it's not a Moen valve assembly).
After much searching, I believe the valve assembly is made by a company called Ultra and the cartridge is part number SVR21W
Of course the logical step is to verify this by removing the old cartridge and thats where my problem is. The old cartridge appears to be threaded in. I've used a 17mm socket to try and remove it but it's just starting to strip the nut.
Any tips on getting this thing out? I'm hoping to avoid removing the faceplate because it's silicone sealed on.
Thanks.
Thanks.
