Mikieboyblue
Hi folks,
I have two different bids for installing a 4 inch drain pipe from the crawlspace through the exterior block and brick veneer wall drained to daylight. This pipe will be used for water heater drain, incidental water in the crawlspace collected by an interior french drain, and discharge from water treatment (softener).
The first proposes to go through the block and brick above grade to a 90 then below grade and the second proposes to go through below grade boring the hole through the footer (I presume) of the at least the brick veneer and is not clear if it will also go through the footer of the block or actual block (no interior excavation has been done). Both are 5 inch holes. My concern with the below grade approach is integrity of the footer although I have been told this will not be a problem. It is about 18" from a corner.
Does anyone have any thoughts or experience in this space?
Thank you in advance!
Mike
Mike
