maddawg995
Hi All,
My contractor installed a standard 14-16" trip lever (Gerber brand) stopper for my new tub which requires a 17" system. Of course, he neglected to tell me until the job was done and now the tub won't hold water. Can I remove the lever plate and drain cover and swap it with a toe tap system? Would it be possible to add another link to the current chain? If so, where can I find it as I searched high and low for something that'll work with no luck. Ripping out the tub and redoing it is not an option. Would also prefer a permanent solution rather done using one of those drain stopper pads. Any advice would be greatly appreciated.
Thanks in advance for your help.
