Tub supply line draining for *hours*
Discussion in 'General Plumbing Help' started by Edward Rowe, Jan 10, 2019.
  1. Jan 10, 2019 #1
    Edward Rowe
    Edward Rowe
    Edward Rowe
    Jan 10, 2019
    Raleigh, NC
    I need to service the cold water faucet on my tub. It's leaking under the handle. I turned off the main, opened the cold water supply to the tub to drain the line. Four hours later, and it's still draining, and with at least i'd say half the normal pressure (this isn't a dribble). No water is available at any other tap in the house. What's going on?
  2. Jan 10, 2019 #2
    CT18
    CT18
    CT18
    Apr 30, 2014
    491
    122
    Bloomfield Hills, Michigan
    Valve isn't holding
  3. Jan 10, 2019 #3
    Mikey
    Mikey
    Mikey
    Well-Known Member Supporting Member
    Jul 16, 2018
    219
    33
    Northwest Washington
    Is the water that's draining cold?
  4. Jan 10, 2019 #4
    Edward Rowe
    Edward Rowe
    Edward Rowe
    Jan 10, 2019
    Raleigh, NC
    Yes, the water is cold. I thought about that too.
  5. Jan 10, 2019 #5
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    219
    33
    Drat. Well, the water is coming from somewhere, which means the main shutoff isn't shutting off, but doesn't explain why there's no flow elsewhere, unless there's gravity getting involved somehow. Can you plug the leaky faucet to stop that leak, and see if you can encourage flow elsewhere? Open the nearest-to-the-shower cold-water faucet, stop the leaker as best you can, and see if you can divert water to the nearby faucet. You might also try shutting things off at the meter. If you do determine that the main shutoff is leaking, this would be a dandy time to replace it. How old is the house?
  6. Jan 10, 2019 #6
    Edward Rowe
    Edward Rowe
    Edward Rowe
    Jan 10, 2019
    Raleigh, NC
    I thought about shutting off at the curb, but the Town's meter befuddled me - at least in the 30 seconds I spent looking at it. The house is only 12 years old which makes me really hope the main valve isn't failing. I'll try force-diverting the flow to another faucet, and give another try at the curb when I get home.
  7. Jan 11, 2019 #7
    CT18
    CT18
    CT18
    Apr 30, 2014
    491
    122
    Is it a ball valve or gate valve that you shut. If it is a gate you could try to put a wrench on it to tighten it a little more. Be gentile though
  8. Jan 11, 2019 #8
    Edward Rowe
    Edward Rowe
    Edward Rowe
    Jan 10, 2019
    Raleigh, NC
    It's a gate valve.
  9. Jan 11, 2019 #9
    CT18
    CT18
    CT18
    Apr 30, 2014
    491
    122
    Throw some channel locks on the handle and give a little tighten carefully, you could snap the stem. Or cut the pipe down stream and pop on a sharkbite ball valve to try and stop the flow
    jeffmattero76 likes this.
  10. Jan 11, 2019 #10
    TomFOhio
    TomFOhio
    TomFOhio
    Professional Professional
    Jan 20, 2018
    812
    183
    Mansfield,, Ohio
    Be careful tightening the gate valve like ct18 said. They also are noted to stay in the valve when you go to open it back up. Can you pull
    the handle off and see if there is a packing nut that you can tighten up. You don't need to turn the water off to do this.
  11. Jan 11, 2019 #11
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    North Reading, Mass.
    Out of curiosity...
    Is that tub faucet the lowest CW outlet in your house?
    And you said, "No water is available at any other tap in the house"?
    With those other CW taps open, can you put your hand over the tub flow and stop it?
  12. Jan 11, 2019 #12
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,311
    I would rather be twitterpated than befuddled
    your water meter on/off valve most likely looks like this
    it is a 1/4 turn valve
    insert a screwdriver as shown [handle] into a crescent wrench
    use as a t wrench to turn valve
  13. Jan 12, 2019 #13
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    I thought the OP said he has a gate valve.
  14. Jan 12, 2019 #14
    TomFOhio
    TomFOhio
    TomFOhio
    Jan 20, 2018
    812
    183
    Mansfield,, Ohio
    Send a picture of your main shut off valve.
    Thanks.
  15. Jan 12, 2019 #15
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,311
    it is not uncommon for a building to have 2 valves
    a curb stop
    then a valve after the meter. which belongs the the home owner
  16. Jan 12, 2019 #16
    Mikey
    Mikey
    Mikey
    Jul 16, 2018
    219
    33
    If he's in NC, the curb stop is probably buried pretty deep. He might have to find a meter valve wrench. Handy to have anyway, and only $15 at the big box store.
  17. Jan 12, 2019 #17
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    In my neck of the woods, only the water department is allow to access the curb stop.
    And the valve located just upstream of my, basement located, meter, is my responsibility.
    It is a good idea to have 2 main shut off valves around the meter, though.
  18. Jan 12, 2019 #18
    frodo
    frodo
    frodo
    Sep 28, 2014
    7,400
    2,311
    AH....Down here We do not have basements, and the frost line is only a foot
    the meter is out by the curb in front of the house
    we install a ball valve so the home owner can turn the water on /off with out pissing off the city
    true story
    many years ago, I was topping out a house, the water line was run but not tied into the meter on the rough in
    the meter was in a mud hole and was crooked on a 22 degree angle.
    99.9% of the city water lines to the meter are soft copper. So I grabbed the meter and pulled it up level
    LOL This was hooked up with plastic and I said OH F____K !!! as I head the plastic break
    woooooooosh.....I grabbed a dresser coupling, nipple and valve
    Installed it on a live line drove a 2x4 in front of it and went to the house
  19. Jan 12, 2019 #19
    Diehard
    Diehard
    Diehard
    Aug 19, 2017
    1,337
    238
    Funny!
    Thank goodness you had that dresser handy.
    Although you would have thought of something else. Like squishing the pipe closed with something.:eek:
Share This Page
